操作方法
有时可能需要将 ArcGIS Insights Desktop 移动到新计算机。 您可以将每个工作簿导出到新计算机,但可能会丢失本地内容。 以下步骤提供了执行此操作的替代方法。
The below steps have not yet been formally tested and are not documented, therefore this procedure is not officially supported. For example, there may be an issue if the username on both machines is not exactly the same. Also, moving from macOS to Windows, and vice versa would not work.
%APPDATA%\Esri\ArcGIS Insights
文章 ID: 000027165
获取来自 ArcGIS 专家的帮助
立即开始聊天
