问题
问题:ArcMap 中的地图打印或导出存在不均匀、分块、质量较差或栅格波段
Last Published: July 9, 2024
描述
Maps printed or exported from ArcMap are bitmapped, scattered, banded, or display with low quality.
原因
This happens for several reasons, independently or combined:
  • The maps are printed or exported with either a low output resolution or a low Output Image Quality (OIQ) setting
  • The map uses a picture/bitmap fill, picture marker, and/or transparent symbology
When exported or printed, ArcMap flattens and rasterizes the layer that is symbolized with either a picture fill, picture marker or transparency, and any layers beneath it in the Table Of Contents (TOC).
Other data frames in the map that do not contain picture fills, picture markers, or transparency are not affected.
解决方案或解决方法
It is highly recommended to use ArcGIS Pro for printing and exporting, especially when experiencing issues caused by the limitations of the ArcMap display engine. More specifically, ArcGIS Pro is not restricted by the graphical device interface (GDI) limitations that some users experience in ArcMap. For example, transparency is natively supported in ArcGIS Pro, preventing the rasterization of layers. Additionally, ArcGIS Pro supports transparency in layout elements. See Migrate from ArcMap to ArcGIS Pro for more information.
ArcGIS Pro does not support exporting Adobe Illustrator files; it is recommended to export using PDF or SVG instead.
If using ArcGIS Pro is not an option, use any of the following options below.
  • Increase the output resolution.
  • Increase the Output Image Quality (OIQ) setting.
  • Reorder the map elements and layers to have layers containing picture fill, picture marker, or transparent symbols at the lowest possible order in the Table Of Contents.
  • Replace the Picture Fill symbols with simpler, vector fills.
  • Replace the Picture Marker symbols with font-based vector marker symbols.
  • Remove transparency. For exported maps, transparency can be re-applied to the desired elements in an external editing application, such as Adobe Illustrator.
文章 ID: 000002772
获得人工智能支持
使用 Esri Support AI Chatbot 快速解决您的问题。
立即开始聊天
相关信息
发现关于本主题的更多内容
获取来自 ArcGIS 专家的帮助
联系技术支持部门
立即开始聊天
转至下载选项
