常见问题
注: ArcSDE 软件(包括应用程序服务器、命令工具以及带有 C 和 Java API 的 SDK)在 ArcGIS 10.2.2 中已弃用,不再进行分发。
在通过 ArcSDE 将数据加载到 Oracle Spatial 格式时,可以使用以下 DBTUNE 设置示例。
请注意以下几点:
##SDO_TAS ATTRIBUTE_BINARY "LONGRAW" GEOMETRY_STORAGE "SDO_GEOMETRY" A_INDEX_ROWID "TABLESPACE SDE_IDX NOLOGGING PCTFREE 10 INITRANS 4" A_INDEX_SHAPE "TABLESPACE SDE_IDX NOLOGGING PCTFREE 10 INITRANS 4" A_INDEX_STATEID "TABLESPACE SDE_IDX NOLOGGING PCTFREE 10 INITRANS 4" A_INDEX_USER "TABLESPACE SDE_IDX NOLOGGING PCTFREE 10 INITRANS 4" A_STORAGE "TABLESPACE SDE_DATA PCTFREE 10 PCTUSED 90 INITRANS 4" B_INDEX_ROWID "TABLESPACE SDE_IDX NOLOGGING PCTFREE 10 INITRANS 4" B_INDEX_SHAPE "TABLESPACE SDE_IDX NOLOGGING PCTFREE 10 INITRANS 4" B_INDEX_USER "TABLESPACE SDE_IDX NOLOGGING PCTFREE 10 INITRANS 4" B_STORAGE "TABLESPACE SDE_DATA PCTFREE 10 PCTUSED 90 INITRANS 4" D_INDEX_DELETED_AT "TABLESPACE SDE_IDX NOLOGGING PCTFREE 10 INITRANS 4" D_INDEX_STATE_ROWID "TABLESPACE SDE_IDX NOLOGGING PCTFREE 10 INITRANS 4" D_STORAGE "TABLESPACE SDE_DATA PCTFREE 10 PCTUSED 90 INITRANS 4" SDO_COMMIT_INTERVAL 500 SDO_DIMNAME_1 "X" SDO_DIMNAME_2 "Y" SDO_INDEX "RTREE" SDO_INDEX_SHAPE "tablespace=SDE_SP_IDX" SDO_LB_1 0.000000 SDO_LB_2 5000000.000000 SDO_SRID 81936 SDO_TOLERANCE_1 0.000500000000 SDO_TOLERANCE_2 0.000500000000 SDO_UB_1 1000000.000000 SDO_UB_2 6000000.000000 SDO_VERIFY "TRUE" END
注: 自 ArcSDE 9.x 版本起,任何 DBTUNE 关键字中的 SDO_VERIFY 参数现在已废弃,无法使用。
文章 ID:000005646
获取来自 ArcGIS 专家的帮助
下载 Esri 支持应用程序
