操作方法
操作方法:在 Windows 上具有基础 ArcGIS Enterprise 部署的同一台计算机上安装 ArcGIS Notebook Server
Last Published: September 12, 2023
摘要
When installing ArcGIS Notebook Server on Windows, the installation of Docker Desktop causes entries to be written to the machine's hosts file that could cause problems with the way our software interprets the machine name.
This installation method assumes that all system requirements are met, keeping in mind that all minimum system requirements (CPU, RAM, storage) for each component are additive to maintain a supported environment.
原因
Docker Desktop installed on a Windows machine writes entries to the system's hosts file that use the machine IP address to identify both host.docker.internal and gateway.docker.internal. This could potentially be picked up by other components of ArcGIS Enterprise, Portal for ArcGIS, ArcGIS Server, ArcGIS Notebook Server, and ArcGIS Data Store, and not only cause a name change in the software's definition of the machine but also cause auxiliary issues in how ArcGIS Server and ArcGIS Data store communicate.
The following image shows an example hosts file following Docker Desktop installation:
image of hosts file
过程
As a precaution, to prevent the components of ArcGIS Enterprise from using the incorrect machine name for configuration and communication (due to the host file entry made by installing Docker Desktop), follow the instructions for each component to define the hostname to the software before installation of Docker Desktop.
This includes adding an entry for hostname=machine.domain.com in the created hostname.properties file for ArcGIS Enterprise Portal, ArcGIS Server, and ArcGIS Notebook Server, as well as adding an entry in the hostidentifier.properties file for hostidentifier=machine.domain.com for ArcGIS Data Store.
Ideally, this would be done before creating each of the respective sites, but can also be performed after configuration if the machine names are confirmed in the Admin > Machine endpoints for ArcGIS Portal and ArcGIS Server.
Documentation can be found in the Related Information section below, in the 'Multiple NICs or DNS entries' sub-heading for each product.
文章 ID: 000022812
获得人工智能支持
使用 Esri Support AI Chatbot 快速解决您的问题。
立即开始聊天
相关信息
发现关于本主题的更多内容
获取来自 ArcGIS 专家的帮助
联系技术支持部门
立即开始聊天
转至下载选项
