问题
问题:当一台计算机上有多个 Data Interoperability 产品时,Data Interoperability 存在不兼容性
Last Published: April 29, 2024
描述
When more than one Data Interoperability product is installed on a single machine, there are known issues with the compatibility and functionality of the Data Interoperability installation. Documented in this technical article are a list of install sequences of the Data Interoperability products, the problem that occurs, and the workaround for the issue.
Installed FirstInstalled SecondProblem
ArcGIS Data Interoperability 10.6 for DesktopData Interoperability for ArcGIS Pro 2.1ArcGIS Data Interoperability 10.6 for Desktop Quick Import/Export dialog script error in MdDlgContent.htm
ArcGIS Data Interoperability 10.6 for DesktopData Interoperability for ArcGIS Pro 2.1ArcGIS Data Interoperability 10.6 for Desktop Interoperability connections can be created but do not work
Data Interoperability for ArcGIS Pro 2.1ArcGIS Data Interoperability 10.6 for DesktopData Interoperability for ArcGIS Pro 2.1 Quick Import input dataset picker cannot browse
Data Interoperability for ArcGIS Pro 2.1ArcGIS Data Interoperability 10.6 for DesktopData Interoperability for ArcGIS Pro 2.1 Quick Export output dataset picker cannot browse
Data Interoperability for ArcGIS Pro 2.1ArcGIS Data Interoperability for Server for 10.6ArcGIS Data Interoperability for Server for 10.6 fails to publish Spatial ETL tools
原因
Esri is aware of the underlying cause of these issues and is working to get them fixed.
解决方案或解决方法
Until a permanent fix for these issues becomes available, Esri recommends the workaround listed below.
First / SecondWorkaround
ArcGIS Data Interoperability 10.6 for Desktop /
Perform a repair install of ArcGIS Data Interoperability 10.6 for Desktop.
Data Interoperability for ArcGIS Pro 2.1 /
Perform a repair install of Data Interoperability for ArcGIS Pro 2.1.
No workaround for side-by side-operation exists. Uninstall ArcGIS Data Interoperability for Server 10.6.
文章 ID: 000017667
获得人工智能支持
使用 Esri Support AI Chatbot 快速解决您的问题。
立即开始聊天
发现关于本主题的更多内容
获取来自 ArcGIS 专家的帮助
联系技术支持部门
立即开始聊天
转至下载选项
