问题
问题:在 ArcGIS Pro 中,Business Analyst“丰富图层”工具针对某些标准地理贸易区域输入要素返回“零”值
Last Published: July 21, 2023
描述
In ArcGIS Pro, the Business Analyst Enrich Layer tool returns 'zero' values for Standard Geography Trade Area input features for the following variables:
  • Dominant Tapestry Segment Name
For example, if an Enrich Layer operation is run on ZIP Code Boundary 94105, the returned values should be:
  • Dom Tapestry Segment Name:  Laptops and Lattes
  • Dominant Tapestry Segment:  3A
Below is an image of the correct output, as described above:
The actual values returned are both '0'.  The tool should aggregate Tapestry data in the containing block groups to calculate dominant values in the ZIP code, or any other selected boundary. Below is an image of the  incorrect output:
When the Business Analyst Data Source is set to use online data, the variables are correctly returned.
原因
A script that summarizes this variable with a locally installed dataset is incorrectly set to not display the aggregation.
解决方案或解决方法
  1. Close ArcGIS Pro.
  2. Download and unzip the file: US_summarizations_esri.xml.zip.
  3. Copy unzipped US_summarizations_esri.xml to:
C:\ArcGIS\Business Analyst\US_2019\Data\Demographic Data (or the location of the locally installed dataset)
  1. Overwrite the existing xml file.
  2. Open ArcGIS Pro.
  3. Run Enrich Layer with a ZIP Code Standard Geography input feature.
  4. Choose variables: Dom Tapestry Segment Name, and Dominant Tapestry Segment.
Result:  The Enrich Layer output feature should have populated values, and not zeroes.
文章 ID: 000022798
获得人工智能支持
使用 Esri Support AI Chatbot 快速解决您的问题。
立即开始聊天
相关信息
发现关于本主题的更多内容
获取来自 ArcGIS 专家的帮助
联系技术支持部门
立即开始聊天
转至下载选项
