操作方法
When using the Select by Attributes tool, query operators such as IN, LIKE, OR, and NOT can be used to determine the type of selection for multiple values. Refer to ArcMap: SQL reference for query expressions used in ArcGIS for more information on the query operators types.
The following workflow uses the IN query operator to select multiple values. This workflow is also applicable to the other query operators; LIKE, OR, and NOT.
> Select By Attributes.
Note: If it is a text field, apply single quotes around each value.
The following is a sample query:
<field name> IN (<field value>, <field value>)
Note: This method can also be used to select numeric and string values.
文章 ID: 000009011
获取来自 ArcGIS 专家的帮助
立即开始聊天
