操作方法
有时,我们希望匹配已发布的引用要素图层中使用的源企业级地理数据库要素类和企业级地理数据库表。 此图层可能使用了多个子图层和表。 以下脚本将在 .sde 连接中检索子图层/表名称及其 ID/索引和源表/要素类名称。
使用 ArcGIS Pro Python 环境运行以下脚本:
from arcgis.gis import GIS
from arcgis.features import FeatureLayerCollection
import arcpy
import re
#Log in to ArcGIS Enterprise
portalurl = 'https://hostname.esri.com/portal'
username = 'admin'
password = 'admin123'
gis = GIS(portalurl,username,password)
arcpy.SignInToPortal(portalurl,username,password)
#Specify the referenced Feature Layer item ID
featurelayeritem = gis.content.get('c800e0fe96b844cfb7e6a684383da43f')
#Specify the workspace to be the REST URL of the feature layer
arcpy.env.workspace = f"{featurelayeritem.url}"
#Identify a list of all source feature classes and tables
featureclasses = arcpy.ListFeatureClasses()
sourcetables = arcpy.ListTables()
"""The above will create a list of strings with source feature
classes and another for source tables used in the layer.
The result will be ['L<id><featureclass>']. For examble, if
the feature class is called 'Addresses', and the associated
layer id is '3', it will be ['L3Addresses']."""
#The below is to retrieve layers and tables information from the web feature layer
featurelayercollection = FeatureLayerCollection.fromitem(featurelayeritem)
layers = featurelayercollection.properties['layers']
tables = featurelayercollection.properties['tables']
#Looping through each layer
for layer in layers:
#Retrieving the layer name and its id
layername = layer['name']
layerid = layer['id']
#Looping through the source feature classes
for featureclass in featureclasses:
#Retrieving only the feature class name that starts with "L<layerid>"
if featureclass.startswith(f'L{layerid}'):
"""Making sure that, for example, the layer wth id 33
doesn't get retrieved with the one with 3 id. So we
make sure that the character after L<layerid> is a
letter not a number as feature classes can only start
with letters"""
prefixlength = len(f'L{layerid}')
if re.match(r'[A-Z,a-z]',featureclass[prefixlength:]):
#Identifying the sourcename without 'l<layerid>'
sourcename = featureclass[prefixlength:]
#Printing the result
print(f'Layer name: {layername}')
print(f'Layer ID: {layerid}')
print(f'Source Feature Class: {sourcename}')
print('-----------------------------------')
#Looping through each table
for table in tables:
#Retrieving the table name and its id
tablename = table['name']
tableid = table['id']
#Looping through the source tables
for sourcetable in sourcetables:
#Retrieving only the table name that starts with "L<tableid>"
if sourcetable.startswith(f'L{tableid}'):
"""Making sure that, for example, the table wth id 33
make sure that the character after L<tableid> is a
with letters"""
prefixlength = len(f'L{tableid}')
if re.match(r'[A-Z,a-z]',sourcetable[prefixlength:]):
#Identifying the sourcename without 'l<tableid>'
sourcename = sourcetable[prefixlength:]
print(f'Table name: {tablename}')
print(f'Table ID: {tableid}')
print(f'Source Table: {sourcename}')
文章 ID: 000032337
获取来自 ArcGIS 专家的帮助
立即开始聊天
