操作方法
操作方法:从 ArcGIS Pro 属性表的字段中移除和替换字符
Last Published: July 18, 2023
摘要
The instructions provided describe how to remove and replace characters from a field in an attribute table using the Calculate Field tool in ArcGIS Pro. In this example, the hyphens (-) are removed under the Region field of the attribute table, and replaced with a comma (,) for improved readability.
An attribute table with hyphens in the Region field
过程
  1. Open the project in ArcGIS Pro.
  2. Right-click the layer in the Contents pane, and click Attribute Table.
  3. Click the Calculate Field button The Calculate Field button to open the Calculate Field geoprocessing tool.
  4. In the Calculate Field pane, select the field for editing under Field Name (Existing or New). In this example, it is Region. Ensure the Expression Type is Python3.
  5. Under the Expression section, click the field for editing (in this example, it is Region) from the Fields list. Click .replace() from the Helpers list.
  6. Within the bracket in .replace(), type "-","," to replace the hyphens with a comma, as shown below.
 ![FieldName]!.replace("-",", ")
The following demonstrates the proper expression:
 !Region!.replace("-",", ")
  1. Click OK. The tool completes with the hyphens removed and replaced with a comma.
The Calculate Field tool window is to be configured.
  1. Click the Save Edits button The Save Edits button in the Calculate Field pane to save the changes.
The attribute table with the hyphens replaced with commas
文章 ID: 000022616
获得人工智能支持
使用 Esri Support AI Chatbot 快速解决您的问题。
立即开始聊天
相关信息
发现关于本主题的更多内容
获取来自 ArcGIS 专家的帮助
联系技术支持部门
立即开始聊天
转至下载选项
