操作方法
在 ArcGIS Pro 中,可以使用点集转线工具将点要素与线要素连接起来。 在某些情况下,需要将一组点要素的连接线放置在不同的点要素类中的选定点。 但是,通过使用点集转线工具,生成的线仅连接到来自同一点要素类的点,如下图所示。
以下过程介绍如何使用 ArcPy 以编程方式将要素类中的点连接到另一个包含线的要素类中的单个点要素。
import arcpy <VariableName1> = "<PointName1>" <VariableName2> = "<PointName2>" <VariableName3> = "<LineName>"
assert arcpy.management.GetCount(points_layer1)[0] == "1", "select exactly 1 point from <VariableName1>" assert int(arcpy.management.GetCount(points_layer1)[0]) > 0, "select > 0 point(s) from <VariableName2>"
with arcpy.da.SearchCursor(<VariableName1>, ["SHAPE@XY"]) as cursor:
for row in cursor:
end_x, end_y = row[0]
end_point = arcpy.PointGeometry(arcpy.Point(float(end_x), float(end_y)))
if not arcpy.Exists(VariableName3): arcpy.management.CreateFeatureclass(arcpy.env.workspace, "<LineName>", "POLYLINE")
line_array = arcpy.Array()
with arcpy.da.SearchCursor(<VariableName2>, ["SHAPE@XY"]) as cursor:
for row in cursor:
start_x, start_y = row[0]
start_point = arcpy.PointGeometry(arcpy.Point(float(start_x), float(start_y)))
line_array.append(start_point.centroid) line_array.append(end_point.centroid)
line = arcpy.Polyline(line_array) line_array.removeAll()
with arcpy.da.InsertCursor(<VariableName3>, ["SHAPE@"]) as icursor: icursor.insertRow([line])
arcpy.management.MakeFeatureLayer(<VariableName3>,"<LineName>")
以下代码块演示了完整脚本。
import arcpy
points_layer1 = "facilities"
points_layer2 = "pts"
lines_layer = "lines"
assert arcpy.management.GetCount(points_layer1)[0] == "1", "select exactly 1 point from points_layer1"
assert int(arcpy.management.GetCount(points_layer1)[0]) > 0, "select > 0 point(s) from points_layer2"
with arcpy.da.SearchCursor(points_layer1, ["SHAPE@XY"]) as cursor:
for row in cursor:
if not arcpy.Exists(lines_layer):
arcpy.management.CreateFeatureclass(arcpy.env.workspace, "lines", "POLYLINE")
with arcpy.da.SearchCursor(points_layer2, ["SHAPE@XY"]) as cursor:
for row in cursor:
with arcpy.da.InsertCursor(lines_layer, ["SHAPE@"]) as icursor:
arcpy.management.MakeFeatureLayer(lines_layer,"lines")
下图显示了将一组点要素连接到另一个要素类中的所选点要素的线要素。
文章 ID: 000029537
获取来自 ArcGIS 专家的帮助
立即开始聊天
