操作方法
完全卸载表示移除可能会干扰软件新安装的任何文件夹或对 ArcGIS Drone2Map 软件的引用,这是常规故障排除中排除安装过程问题的步骤。 本文提供了执行 ArcGIS Drone2Map 完全卸载的工作流。
Warning: The instructions below may change part of the machine's operating system. Contact the organization's IT department for assistance, if necessary. Esri cannot guarantee results from incorrect modifications while following these instructions.
HKEY_CURRENT_USER\SOFTWARE\ESRI
C:\Users\<username>\Documents
C:\Program Files\ArcGIS
Note: By default, the AppData folder is hidden. Refer to Microsoft: View hidden files and folders in Windows for instructions to display hidden folders.
C:\Users\<username>\AppData\Local
C:\Users\<username>\AppData\Local\ESRI
C:\Users\<username>\AppData\Roaming\ESRI
文章 ID: 000017383
获取来自 ArcGIS 专家的帮助
立即开始聊天
