操作方法
操作方法:在 ArcGIS Server 实例不可用时,生成密钥代码文件以授权企业级地理数据库
Last Published: October 7, 2024
摘要
When authorizing an enterprise geodatabase on an ArcGIS Server instance, a keycodes file is required to complete the authorization process. As the keycodes file is generated during the authorization process, in some instances, when access to an ArcGIS Server instance is unavailable, the authorization process cannot be completed. For example, when a different machine is used for the authorization, or when the server is unavailable.
过程
Follow the steps below to complete the software authorization process, and generate a new keycodes file to authorize an enterprise geodatabase when an ArcGIS Server instance is unavailable.
An authorization file for ArcGIS Server is still required to perform the following procedure. It is not possible to authorize an enterprise geodatabase if only an ArcGIS Pro or ArcGIS Desktop license is available.
  1. On the machine, navigate to the following location:
    • For ArcGIS Pro.
C:\Program Files\ArcGIS\Pro\bin\SoftwareAuthorizationPro.exe
    • For ArcMap.
C:\Program Files (x86)\Common Files\ArcGIS\bin
  1. Double-click SoftwareAuthorization.exe to run the authorization wizard.
  2. In Software Authorization Wizard, under Authorization Options, select I have received an authorization file and am now ready to finish the authorization process..
  3. Click Browse... to select the .ecp authorization file obtained from My Esri. Select the file used to authorize the organization's ArcGIS Server machine.
Refer to the ArcGIS Server administrator to determine the correct ECP file.
  1. For Product to be Authorized, ensure ArcGIS Server is selected, and click Next.
The Software Authorizarion Wizard showing the authorization options
  1. Refer to Steps 7 to 14 of ArcGIS Pro: Authorize a Single Use license to complete the software authorization process.
  2. Navigate to the following location to access the newly created keycodes file and verify the keycodes file is present:
    • For ArcGIS Pro.
C:\Program Files\ESRI\License10.x\sysgen
    • For ArcMap.
C:\Program Files (x86)\Esri\License10.x\sysgen
  1. Authorize the enterprise geodatabase with the newly created keycodes file. Refer to ArcGIS Pro: Update Enterprise Geodatabase License (Data Management) for more information.
文章 ID: 000024911
获得人工智能支持
使用 Esri Support AI Chatbot 快速解决您的问题。
立即开始聊天
相关信息
发现关于本主题的更多内容
获取来自 ArcGIS 专家的帮助
联系技术支持部门
立即开始聊天
转至下载选项
