操作方法
In some instances, it is necessary to exclude non-required values from a field used to label a map. This article describes the workflow to exclude certain values from a field in a feature layer label in ArcGIS Pro. In this example, when labeling a map using a number field, some features in the number field have zero values, and the zeros must be excluded.
icon. The Label icon is highlighted when it is enabled.
icon in the Class section. The Label Class - <layer_name> pane opens.
tab, click the New expression drop-down arrow. Select Create a new expression.Note: Optionally, click Add Clause, select the And clause, and specify it as <field> is not equal to <value> to add another value to be excluded from the label.
The image below displays the map without zeros in the label.
文章 ID: 000025277
获取来自 ArcGIS 专家的帮助
立即开始聊天
