操作方法
操作方法:在 ArcGIS Pro 中启用公共设施网络包工具的调试模式
First Published: October 20, 2020
Last Published: July 19, 2023
摘要
In ArcGIS Pro, it is possible to enable the debug mode when troubleshooting Utility Network Package Tools errors by setting the logging level to ‘DEBUG’. When running a tool from Utility Network Package Tools, and it fails to execute, a pop-up is generated, with detailed information in the Messages section if the debug mode is enabled. This is helpful in identifying the causes for tool failure.
The following image shows the messages from the pop-up window before setting the logging level to 'DEBUG' when a tool fails to execute.
Image of the example of the messages from a pop-up window of a failed tool before setting the logging level
过程
Follow the instructions below to set the logging level to debug mode when troubleshooting a Utility Network Package Tools error in ArcGIS Pro.
  1. In ArcGIS Pro, click the Analysis tab on the top ribbon. Click the drop-down menu next to Python, and select Python Window.
Image of the selected Python Window
  1. In the Python window, insert the following commands:
import untools
untools.logger.setLevel('DEBUG')
Image of the commands in the Python window in ArcGIS Pro
  1. Press Enter.
  2. In the Geoprocessing pane, run the desired tool from Utility Network Package Tools. If the tool fails, click View Details on the progress bar to view the tool's execution details.
The following image shows the messages from the pop-up window after setting the logging level to 'DEBUG' when the tool fails to execute.
Image of the example of the messages from a pop-up window of a failed tool after setting the logging level
文章 ID: 000024444
获得人工智能支持
使用 Esri Support AI Chatbot 快速解决您的问题。
立即开始聊天
相关信息
发现关于本主题的更多内容
获取来自 ArcGIS 专家的帮助
联系技术支持部门
立即开始聊天
转至下载选项
