操作方法
操作方法:在 ArcGIS Server Administrator Directory 中启用地图服务重采样
First Published: December 12, 2016
摘要
Certain areas of a map are unavailable when viewing tiles of a cached map service. At ArcGIS for Server 10.3 and later, a map service can return 'resampling:true|false', indicating whether users can resample tiles for areas where tiles are unavailable. This property is not enabled by default, however it can be added using the ArcGIS Server Administrator Directory. Instructions provided describe how to do this.
Resampling example.
Prerequisites
The following prerequisites are required to perform resampling:
  • A cached map service on ArcGIS for Server 10.3 or later. The following ArcGIS for Server document describes this in detail: Create a map cache.
  • Admin credentials with access to the ArcGIS Server Administrator Directory for the service.
  • The service must be cached and have available scale levels but lack tiles.
原因
过程
  1. Log in to the ArcGIS Server Administrator Directory as an administrator.
  2. Proceed to the URL for the service.
The following is an example for the URL to edit the cached map service:
http://<host>:<port>/<instance>/admin/services/<CachedMapService>/edit
  1. In the Edit MapServer page, under Service Properties, add the following line in the JSON dialog box:
"resampling": true
User-added image
To function properly, the resampling property must be added above the maxRecordCount property in the Service Properties.
  1. Set the MaxScale to the last level for which the map is to be resampled.
  2. Click Save Edits.
文章 ID: 000014822
获得人工智能支持
使用 Esri Support AI Chatbot 快速解决您的问题。
立即开始聊天
相关信息
发现关于本主题的更多内容
获取来自 ArcGIS 专家的帮助
联系技术支持部门
立即开始聊天
转至下载选项
