操作方法
This article describes the steps for a URL Query workflow that allows any user to pull up to 10,000 records related to a single item ID from an Organization's Audit history in ArcGIS Online. This allows retrieving the entire history of a single ArcGIS Online item without having to search or filter through thousands of unrelated events.
Sometimes items exist in Organizations for a very long time, but at some point require the history of the item to be investigated. Rather than pulling the entire audit log for multiple months of events from the Organization, it is possible to create a query to download a log of events related only to one specific item ID. This avoids the confusion of having to piece together a history for a specific item ID from several different event logs containing many unrelated entries.
Step 1: Generate a Token
Step 2: Modify the following URL to fit your needs, and paste your token on the end:
https://<SHORTNAME>.maps.arcgis.com/sharing/rest/portals/self/history?all=true&start=0&sortOrder=asc&fromDate=<YYYY-MM-DD>&num=10000&f=csv&type=i&id=<ITEMID>&token=<TOKEN>
Note: Make sure to set the beginning date to be a few days before the estimated creation date of the item you are querying!
文章 ID:000023873
获取来自 ArcGIS 专家的帮助
下载 Esri 支持应用程序
