操作方法
如何在 ArcGIS Web AppBuilder 中禁用“应用程序状态”弹出窗口?
Last Published: July 27, 2023
摘要
When viewing or after refreshing the ArcGIS Web AppBuilder app, the pop-up message, 'Click to restore the map extent and layers visibility where you left off' is displayed at the bottom-right corner by default. In some cases, it is best to disable the pop-up if it is not required.
Image of the App State pop-up
This article provides steps to disable the App State pop-up in ArcGIS Web AppBuilder.
过程
When the ArcGIS Web AppBuilder app is created, the App state check box is turned on by default. Refer to ArcGIS Web AppBuilder: App state for more information.
  1. Log in to ArcGIS Online or Portal for ArcGIS.
  2. Navigate to Content > My Content.
  3. Browse to the desired Web AppBuilder for ArcGIS app, click More Options Image of the More Options button, and click Edit Application.
Image of the My Content window
  1. On the Attribute tab, under App state, uncheck the Keeps map extent and layers visibility while leaving the app. check box.
Image of the Attribute tab
  1. Click Save to save the app.
The App State pop-up is not displayed when viewing or after refreshing the ArcGIS Web AppBuilder app.
Image of ArcGIS Web AppBuilder
文章 ID: 000023449
获得人工智能支持
使用 Esri Support AI Chatbot 快速解决您的问题。
立即开始聊天
相关信息
发现关于本主题的更多内容
获取来自 ArcGIS 专家的帮助
联系技术支持部门
立即开始聊天
转至下载选项
