操作方法
The last login dates are helpful in determining the list of active users in ArcGIS Enterprise portal and ArcGIS Online. Administrators have the required privileges to view audit logs and remove non-active users to free up licenses for new users. The last login dates can be determined using ArcGIS API for Python.
Complete the steps below to determine the last login date in ArcGIS Enterprise portal and ArcGIS Online using ArcGIS API for Python.
import arcgis import time from arcgis.gis import GIS
gis = GIS("https://domain.esri.com/portal", username="user1", password="pass1", verify_cert=False)
print("connected")
ArcGIS Online
gis = GIS("https://arcgis.com", username="username", password="password")
print("connected")
a_users = gis.users.search(query='', max_users=200) a_users
for a_user in a_users:
if a_user. lastLogin != -1:
last_accessed = time.localtime(a_user. lastLogin/1000)
print(str(a_user. fullName) + " was last active on: {}/{}/{}\n".format(last_accessed[0], last_accessed[1], last_accessed[2]))
else:
print(str(a_user. fullName) + " has never logged in.\n")
The following shows the full script:
import arcgis
import time
#For Portal for ArcGIS
#For ArcGIS Online
print("connected")
a_users
else:
The image below shows the result of the above script.
文章 ID: 000022604
获取来自 ArcGIS 专家的帮助
立即开始聊天
