操作方法
Note: The functionalities of ArcGIS Collector, ArcGIS Explorer, and ArcGIS Tracker are now available in ArcGIS Field Maps. There are no new capabilities planned for these apps—all future updates will be focused on Field Maps. Migration is recommended. See ArcGIS Blog: Migrate to Field Maps for more information.
ArcGIS Tracker 用于追踪移动用户的移动。 有时,需要删除位置以重置用户的移动或者从记录中移除不必要的轨迹。 但是,位置共享图层未指示要素图层定义中的“删除要素”功能。 在 ArcGIS Online 中,可以通过 ArcGIS REST API 使用“删除要素”操作完成此功能。 本文演示了在 ArcGIS REST API 中使用“删除要素”操作从位置共享图层删除轨迹的工作流。
Note: The ability to delete tracks is restricted to administrators.
Note: Deleting individual tracks directly is not supported in ArcGIS Online. Performing the following workflow deletes the user's tracks entirely.
Note: Esri recommends creating a backup of the data by exporting the location sharing layer as a shapefile or CSV file before deleting the track views. Refer to ArcGIS Online: Export data from hosted feature layers for further instructions.
Note: For more information on the clauses used in this workflow, refer to ArcGIS Online: Deleting tracks.
当状态中返回“Completed”时,将从位置共享图层中删除该轨迹。
文章 ID: 000028200
获取来自 ArcGIS 专家的帮助
立即开始聊天
