操作方法
In ArcGIS Pro, DEM files can be used to determine the area covered by slopes with a certain range of slope degrees by converting the DEM file to a polygon feature class. The converted polygon feature layer contains the area information which can be used for land development.
Refer to How To: Convert slopes with certain slope degrees from a DEM file to a polygon feature class in ArcMap for instructions.
These instructions describe how to convert slopes with a certain range of slope degree from a DEM file to a polygon feature class. In this example, slopes with a slope degree of more than 10 degrees are converted to a polygon feature class.
Note: Set class ranges and class breaks according to the data and the range required. In this example, the value (≤ 10) represents slopes with the slope degree range of 0 to 10, while the value (≤ 41.2193412...) represents slopes with the slope degree range more than 10 degrees to 41.22 (the maximum value). For more information, refer to ArcGIS Pro: Reclass by ranges of values.
Note: The new value of 1 represents slopes with the slope degree range of 0 to 10 while new value of 2 represents slopes with the slope degree range of 10 - 41.219341.
A new polygon layer containing the areas of slopes with the slope degree of more than 10 degrees from the Value 2 is displayed in the map.
文章 ID: 000019549
获取来自 ArcGIS 专家的帮助
立即开始聊天
