操作方法
操作方法:在 ArcGIS Pro 中将 CAD 数据转换为 GIS 数据
Last Published: August 17, 2023
摘要
CAD data can be added to ArcGIS Pro as a feature layer. The resulting CAD feature dataset is a read-only feature layer when CAD data is added to a map. When a CAD feature dataset is added to a map, a group layer is created. In CAD software, CAD layers are used to organize data and control visibility as well as the default symbolic properties of entities in the drawing.
The instructions provided describe how to use the CAD To Geodatabase tool in ArcGIS Pro to convert CAD data to GIS data. In this example, the Bldg1_L1.dwg CAD data file is converted to GIS data in ArcGIS Pro.
过程
  1. Start ArcGIS Pro and open a project.
  2. On the ArcGIS Pro ribbon, click Analysis > Tools to open the Geoprocessing pane.
ArcGIS Pro Analysis ribbon
  1. In the Geoprocessing pane, search for and select CAD To Geodatabase (Conversion Tools).
ArcGIS Pro Geoprocessing pane
  1. In the CAD To Geodatabase pane, configure the following parameters.
    1. For Input CAD Datasets, select the collection of CAD files.
    2. For Output Geodatabase, select the output file's location in the geodatabase.
    3. For Dataset, specify the name of the feature dataset.
Refer to ArcGIS Pro: CAD To Geodatabase (Conversion) for further information on the parameters in the CAD To Geodatabase pane.
  1. Click Run.
ArcGIS Pro CAD To Geodatabase pane
文章 ID: 000026432
获得人工智能支持
使用 Esri Support AI Chatbot 快速解决您的问题。
立即开始聊天
相关信息
发现关于本主题的更多内容
获取来自 ArcGIS 专家的帮助
联系技术支持部门
立即开始聊天
转至下载选项
