操作方法
操作方法:在 ArcGIS Pro 中将文本字段转换为日期字段
Last Published: May 31, 2024
摘要
In ArcGIS Pro, the Convert Time Field tool converts time values of a string or numeric field to a date field. The tool can also be used to convert time values stored in string, numeric, or date fields into custom formats, such as days and months.
The instructions provided describe how to use the Convert Time Field tool in ArcGIS Pro to convert a text field to a date field in an attribute table. The DATE_V field in the Nbo_Hood_Clip attribute table shown in the image below is converted to a DATE field in this example.
The Nbo_Hood_Clip attribute table in ArcGIS Pro
过程
  1. Start ArcGIS Pro and open the project.
  2. On the ArcGIS Pro ribbon, click Analysis > Tools to open the Geoprocessing pane.
The ArcGIS Pro Analysis tab
  1. In the Geoprocessing tool search pane, search for Convert Time Field in the search bar, and click Convert Time Field (Data Management Tools).
ArcGIS Pro Geoprocessing tool search pane
  1. In the Convert Time Field pane, configure the following parameters.
    1. For Input Table, select the attribute table.
    2. For Input Time Field, select the field with the time values.
    3. For Input Time Format, select the date format of the field with the time values.
    4. For Output Time Field, define the name of the new converted field.
Refer to ArcGIS Pro: Convert Time Field (Data Management) for further information on the parameters in the Convert Time Field pane.
  1. Click Run.
ArcGIS Pro Convert Time Field pane
文章 ID: 000026575
获得人工智能支持
使用 Esri Support AI Chatbot 快速解决您的问题。
立即开始聊天
相关信息
发现关于本主题的更多内容
获取来自 ArcGIS 专家的帮助
联系技术支持部门
立即开始聊天
转至下载选项
