操作方法
操作方法:使用 ArcGIS Pro 将栅格数据集转换为 XYZ 表格
Last Published: July 27, 2023
摘要
Several software packages can import data from an XYZ format. This article provides instructions to convert a raster dataset into an XYZ table with ArcGIS Pro.
This process requires the Spatial Analyst license.
过程
  1. Open ArcGIS Pro and add the raster dataset.
  2. Find the Sample tool. Refer to ArcGIS Pro: Find a geoprocessing tool for more information.
  3. In the Geoprocessing pane, select the desired raster dataset for Input rasters.
  4. Select the raster dataset again in the Input location raster or point features field. Ensure Resampling technique is set to Nearest.
  5. Specify Output table.
Screenshot of the Sample geoprocessing pane with the values highlighted
  1. Click Run.
  2. Once the geoprocessing is complete, right-click the new table. Click Open.
  3. Export the table and save it with the .txt extension. Refer to ArcGIS Pro: Export tables for more information.
The output text file is in the OID, Z, X, Y format. The image below shows the output file.
Image of a sample output file
文章 ID: 000023278
获得人工智能支持
使用 Esri Support AI Chatbot 快速解决您的问题。
立即开始聊天
获取来自 ArcGIS 专家的帮助
联系技术支持部门
立即开始聊天
转至下载选项
