操作方法
操作方法:在 ArcGIS Desktop 中将图层包转换为 shapefile
Last Published: April 19, 2024
摘要
A layer package is a zipped folder containing the layer properties and the dataset referenced by a layer. In some instances, it is required to convert all the data from a layer package to a shapefile for data analysis purposes. This article provides instructions to convert a layer package to a shapefile in ArcGIS Pro and ArcMap.
过程
ArcGIS Pro
Use the Export Features tool to convert a layer package to a shapefile in ArcGIS Pro.
  1. In ArcGIS Pro, in the Catalog tab, right-click Folders, and select Add Folder Connection.
  2. Select the desired folder containing the layer package file, and click OK to add the folder.
  3. Right-click the layer package file, and select Add To Current Map.
  4. In the Contents pane, right-click the feature layer, and navigate to Data > Export Features.
  5. In the Export Features window, specify the Output Location to save the output feature, and specify the Output Name.
The output location must be a non-geodatabase folder.
  1. Click OK to generate the shapefile.
The Export Features window in ArcGIS Pro to convert a layer package to a shapefile
ArcMap
Use the Feature Class To Shapefile (multiple) tool to convert a layer package to a shapefile in ArcMap.
  1. In File Explorer, select and click the desired layer package file to open it in ArcMap. The image below shows an example of an ArcMap layer package file, Transportation.
An ArcMap layer package file, Transportation, in File Explorer.
  1. Use the Feature Class To Shapefile (multiple) tool to convert the layer package to a shapefile.
    1. In the Geoprocessing pane, navigate to Search for Tools.
    2. Search for the Feature Class to Shapefile (multiple) tool.
    3. For Input Features, select the desired layer package file.
    4. For Output Folder, click the Browse icon to specify the location.
    5. Click OK to generate the shapefile.
The Feature Class to Shapefile (multiple) geoprocessing tool window to convert the layer package file to a shapefile
文章 ID: 000024418
获得人工智能支持
使用 Esri Support AI Chatbot 快速解决您的问题。
立即开始聊天
获取来自 ArcGIS 专家的帮助
联系技术支持部门
立即开始聊天
转至下载选项
