操作方法
操作方法:更改 ArcGIS Pro 地图布局上的动态文本相对比例单位
Last Published: July 20, 2023
摘要
In ArcGIS Pro, the dynamic text scale unit on a map layout can be edited by modifying the Dynamic Text settings. This allows the selection and deployment of a suitable relative scale unit for the dynamic text on the map. Adjust the dynamic text scale unit of a map layout in ArcGIS Pro with the steps provided in this article.
过程
  1. In the layout view, on the top ribbon, click the Insert tab.
  2. In the Graphics and Text group, click the Dynamic Text The Dynamic Text icon button.
  3. View the current scale unit under Relative Scale. In this example, the scale text shows the relative scale from inches to miles.
The Relative Scale showing the current map layout scale unit
  1. Open the Element pane to view the properties of the text element.
The Format Text pane showing the properties of the text element
  1. In the Format Text pane, under Options, expand Text and click Tag View The Tag View icon to view the dynamic text..
  2. Modify the text element as required. In this example, the 'mapUnits' value is changed to 'feet'.
The Dynamic Text window showing the full dynamic text tags
  1. Click OK.
文章 ID: 000025988
获得人工智能支持
使用 Esri Support AI Chatbot 快速解决您的问题。
立即开始聊天
相关信息
发现关于本主题的更多内容
获取来自 ArcGIS 专家的帮助
联系技术支持部门
立即开始聊天
转至下载选项
