操作方法
操作方法:在 ArcGIS Pro 中计算多面体要素的体积
Last Published: November 1, 2023
摘要
In ArcGIS Pro, it is possible to create multipatch features, and calculate the volume of enclosed multipatch features using the Add Z Information tool. This article describes the workflow to calculate the volume of enclosed multipatch features.
过程
  1. Open the ArcGIS Pro project.
  2. Ensure the multipatch layer is projected in a Projected Coordinate System. To check the layer's coordinate system, refer to the following steps:
    1. On the Contents pane, right-click the layer, and click Properties.
    2. In the Layer Properties window, click the Source tab, and expand the Spatial Reference group.
The data must be projected in a Projected Coordinate System because volumes are calculated based on linear units of measurement. If the data is in a Geographic Coordinate System, the volumes cannot be calculated based on angular units of measurement.
  1. If the multipatch layer is projected in a Geographic Coordinate System, project the layer to a Projected Coordinate System using the Project tool.
    1. On the top ribbon, click the Analysis tab > Tools.
    2. In the Geoprocessing pane, search for Project (Data Management) and click it. The Project window opens.
    3. In the Project window, click Parameters.
    4. Click the drop-down menu of Input Dataset or Feature Class, and select the multipatch layer. In this example, the layer is Multipatch_Test.
    5. For Output Dataset or Feature Class, specify a name for the output layer and its location. In this example, the output name is Multipatch_Test_Project_PCS.
    6. For Output Coordinate System, select a Projected Coordinate System for the multipatch layer under Projected Coordinate System in the Coordinate System window. In this example, NAD 1983 HARN Contiguous USA Albers is selected.
    7. Click Run.
The Project window displaying the Input Dataset or Feature Class, Output Dataset or Feature Class, and Output Coordinate System parameters.
  1. Calculate the volume of the multipatch features using the Add Z Information tool.
    1. In the Geoprocessing pane, search for Add Z Information (3D Analyst) and click it. The Add Z Information window opens.
    2. In the Add Z Information window, click Parameters.
    3. For Input Features, select the multipatch layer projected in the Projected Coordinate System. In this example, the layer is Multipatch_Test_Project_PCS.
    4. For Output Property, check the Volume check box.
    5. Click Run.
The Add Z Information window displaying the Input Features and Output Property parameters.
The following image shows the multipatch layer attribute table with the calculated volume of multipatch features in the Volume field.
The attribute table of the multipatch layer displaying the calculated volumes.
文章 ID: 000026288
获得人工智能支持
使用 Esri Support AI Chatbot 快速解决您的问题。
立即开始聊天
相关信息
发现关于本主题的更多内容
获取来自 ArcGIS 专家的帮助
联系技术支持部门
立即开始聊天
转至下载选项
