操作方法
操作方法:在 ArcGIS Pro 中调整定位器的最低匹配得分或最低候选得分
Last Published: November 1, 2023
摘要
In ArcGIS Pro, locators can be used to perform geocoding. When a locator is created, the default parameters of the geocoding properties and options are saved in the locator. In some instances, the minimum match score or minimum candidate score must be adjusted. For example, if the locator is unable to find candidates for an address, the minimum candidate score must be reduced to enable candidates with lower scores to display.
To adjust the minimum match score or the minimum candidate score of a locator in ArcGIS Pro, follow the steps below.
过程
ArcGIS Pro currently supports accessing and modifying locator properties for locators added to a project and stored in a file location, but not for portal locators or server locators.
  1. In ArcGIS Pro, open the project.
  2. In the Catalog pane, navigate to the Locators folder or the folder connection containing the locator.
  3. Right-click the locator, and select Locator Properties.
The Locator Properties for a locator in the Catalog pane of ArcGIS Pro.
  1. In the Locator Properties dialog box, select Geocoding options.
  2. Under Minimum match score or Minimum candidate score, type a score between zero and one hundred in the box.
Showing the minimum match score and minimum candidate scores in the Locator Properties dialog box.
  1. Click OK to apply the changes.
文章 ID: 000025078
获得人工智能支持
使用 Esri Support AI Chatbot 快速解决您的问题。
立即开始聊天
相关信息
发现关于本主题的更多内容
获取来自 ArcGIS 专家的帮助
联系技术支持部门
立即开始聊天
转至下载选项
