常见问题
Categorical rasters present some challenges when performing a merge operation since the rasters have attribute tables with additional information on the pixel values. Standard rasters often only have one bit of information per pixel. It can be difficult to merge several categorical rasters since there are limitations to using the Append tool and the way mosaic datasets handle thematic rasters. The following is an associated limitation: Bug: NIM089347.
The following blog post describes the workflows to merge categorical rasters into a mosaic dataset, ArcGIS Blog: Managing categorical rasters in ArcGIS Workflow. The output mosaic dataset has one attribute table and a colormap, and can be published and used as a single dataset. As pointed out in the blog post, it is important to note that the attribute table is not stored in the mosaic dataset, and when moving the mosaic dataset, users must set an accessible raster attribute table location in the mosaic dataset's Function tab.
Alternatively, use the following workaround. This workflow retains the attribute table with the raster and creates a single raster, while getting around the limitation of using the Append tool with categorical rasters.
文章 ID: 000016361
获取来自 ArcGIS 专家的帮助
立即开始聊天
