问题
问题:ArcGIS Server Manager 日志中返回“重排服务失败”
描述
When publishing a service in ArcGIS for Server, the following error message is written to the ArcGIS Server Manager log file.
Error: Failed swizzling the service.
User-added image
原因
This issue is commonly seen on machines with ArcGIS for Server 10.4 or 10.4.1 installed. The issue is due to a bug, which is addressed here: BUG-000096292.
In ArcGIS for Server, swizzling is the process of renaming paths for layers, and other data within a map document to ready the MXD before it is used by ArcGIS for Server after being published. At publishing, the MXD is placed into a service definition file (.sd), copied to the ArcGIS for Server machine, and un-packaged for use in the service. When data is copied to ArcGIS for Server, the paths must be changed to point to the ArcGIS for Server directories where the copied MXD and data reside.
If a registered data store is part of the workflow where the ArcGIS for Server and publishing locations do not match, the corresponding paths are swizzled. The following document provides an in-depth explanation when the publisher machine and ArcGIS for Server are working with different databases: About registering your data with ArcGIS Server.
解决方案或解决方法
Install the ArcGIS for Server Publishing Patch. This patch fixes issues related to the publishing of GIS services. The patch can be found here: ArcGIS for Server Publishing Patch.
文章 ID: 000014719
获得人工智能支持
使用 Esri Support AI Chatbot 快速解决您的问题。
立即开始聊天
相关信息
发现关于本主题的更多内容
获取来自 ArcGIS 专家的帮助
联系技术支持部门
立即开始聊天
转至下载选项
