常见问题
常见问题解答:ArcGIS Desktop 版本的 Data Interoperability 扩展模块的内部版本号有哪些?
Last Published: May 9, 2024
There are different versions for the Data Interoperability extension. ArcMap is a 32-bit application, and ArcGIS Pro is 64-bit, so the version of the extension depends on the application used.
To find the build number for the version of Data Interoperability extension installed with ArcMap, open ArcCatalog or ArcMap and click Customize > Extensions. Select the Data Interoperability extension from the list of installed extensions. The build number is displayed at the bottom of the window.
The build number for the Data Interoperability extension installed with ArcMAp 10.5.1 is 17271, as demonstrated in the screenshot below.
ArcGIS Desktop extensions dialog showing Data Interoperability Build number
The table below shows the versions of ArcMap and their corresponding Data Interoperability build numbers.
ArcMap versionData Interoperability Build #
9.3.15658
10.06213
10.0 SP1 / SP26233
10.112229
10.1 SP112265
10.2 / 10.2.113540
10.2.214241
10.314411
10.3.115245
10.415573
10.4.116177
10.516661
10.5.117271
10.617650
10.6.118301
10.718567
10.7.119238
10.819630
10.8.120218
Prior to version 10.1 of ArcGIS Desktop, the Data Interoperability extension was included with all other extensions in the software download. To better coordinate the distribution of the Data Interoperability extension with Safe Software, at 10.1 and subsequent versions, Data Interoperability is now separately downloaded and installed.
文章 ID: 000012600
获得人工智能支持
使用 Esri Support AI Chatbot 快速解决您的问题。
立即开始聊天
相关信息
发现关于本主题的更多内容
获取来自 ArcGIS 专家的帮助
联系技术支持部门
立即开始聊天
转至下载选项
