常见问题
Note: This article is contributed by Esri Canada.![]()
The projections and geographic coordinate systems (GCSs) used to define data in ArcGIS are an important part of working with GIS data. Below is an overview of some of the most common projections and geographic coordinate systems for Canada.
Geographic coordinate system: A reference system that uses latitude and longitude to define the locations of points on the surface of a sphere or spheroid. A geographic coordinate system definition includes a datum, prime meridian, and angular unit.
Commonly used geographic coordinate systems in Canada
Projected coordinate system: A projected coordinate system is defined by a geographic coordinate system, a map projection, parameters required by the map projection, and a linear unit of measure. Every map projection distorts distance, area, shape, direction, or some combination thereof.
Commonly used projected coordinate systems in Canada
For more information about the terms geoid, ellipsoid, spheroid, and datum, refer to What do the terms geoid, ellipsoid, spheroid and datum mean, and how are they related?
文章 ID: 000011853
获取来自 ArcGIS 专家的帮助
立即开始聊天
