常见问题
常见问题解答:是否可以从“命令提示符”启动 ArcGIS Pro 工程?
Last Published: January 11, 2024
Yes, it is possible to launch an ArcGIS Pro project from the Command Prompt. The Command Prompt is a command line interpreter application in a text-based user interface screen of an operating system or program. It is used to perform commands entered in the application.
The workflow below describes how to launch an ArcGIS Pro project from the Command Prompt.
  1. Click Start > Windows System > Command Prompt, or search for and click Command Prompt in the search box on the taskbar.
  2. Specify the command line of the directory path to the project file and the filename with the file extension (.aprx). The following is an example of the command line format:
"<ProjectDirectory>\<ProjectName>"
Ensure the double quotes are present around the command line to properly execute the command.
  1. Press the Enter key. The image below is an example of the command line.
"C:\Users\<username>\Documents\ArcGIS\Projects\LabelMapFeatures\Portland Labels.aprx"
The Command Prompt window with the command line.
文章 ID: 000026068
获得人工智能支持
使用 Esri Support AI Chatbot 快速解决您的问题。
立即开始聊天
相关信息
发现关于本主题的更多内容
获取来自 ArcGIS 专家的帮助
联系技术支持部门
立即开始聊天
转至下载选项
