错误
错误:导出操作失败。 名称为空
错误消息
When exporting an ArcGIS Server site (.agssite) file using the Export Site operation in ArcGIS Server Administrator Directory, the following error is returned in the ArcGIS Server logs:
Error:
Export operation failed. Name is Null
[O-Image]
原因
The following are possible causes of this error.
  • The ArcGIS Server jobs folder contains a locked file from a previous job. This can occur when a job does not complete its execution process and becomes inactive, and prevents the job from exporting.
  • Detached job folder. One of the causes of inactive jobs is if the related primary process, upon completing its task, is deleted manually without terminating the inactive process.
  • Running the ArcGIS Server backup utility can return this error. This can be caused by a corrupt installation of ArcGIS Server.
解决方案或解决方法
The following are possible solutions for this error.
  • Remove the inactive jobs and export the site again.
    1. Log into the machine hosting the ArcGIS Server jobs, navigate to,C:\arcgisserver\config-store\system\jobs, and remove the inactive job.
    2. Log into ArcGIS Server Administrator Directory and navigate to, Home > exportSite. Include the Export Site parameters if required, and click Export.
  • Reinstall ArcGIS Server. Refer to ArcGIS Enterprise: Welcome to the ArcGIS Server (Windows) installation guide for detailed instructions.
文章 ID: 000012918
获得人工智能支持
使用 Esri Support AI Chatbot 快速解决您的问题。
立即开始聊天
相关信息
发现关于本主题的更多内容
获取来自 ArcGIS 专家的帮助
联系技术支持部门
立即开始聊天
转至下载选项
