错误
错误:无法连接到数据库。 数据库不接受连接。 请联系地理数据库管理员
错误消息
In ArcGIS for Desktop, in some instances when attempting to establish a connection to a geodatabase the following error is returned.
Error:
Failed to connect to database. The geodatabase is not accepting connections. Please contact your geodatabase administrator.
image of error message
原因
This issue occurs if the Geodatabase is accepting connections check box is unchecked in the database properties, which prevents new connections to be made to the geodatabase.
解决方案或解决方法
Enable the Geodatabase is accepting connections option.
  1. In ArcMap, navigate to the Catalog pane.
  2. Right-click the target database > PropertiesConnections tab.
  3. Check the Geodatabase is accepting connections check box.
  4. Click Apply to confirm the new database connection settings.
文章 ID: 000014329
获得人工智能支持
使用 Esri Support AI Chatbot 快速解决您的问题。
立即开始聊天
相关信息
发现关于本主题的更多内容
获取来自 ArcGIS 专家的帮助
联系技术支持部门
立即开始聊天
转至下载选项
