操作方法
尝试通过 ArcGIS Enterprise 要素服务在 ArcGIS QuickCapture 中创建新工程时,将返回以下错误:
Error: Can't create project due to an unknown error
Please try again. If the error persists, please contact Esri Support.
在 ArcGIS Server 日志中,将返回以下错误:
Error: Error performing submit job operation Error handling service request D:\arcgisserver\directories\arcgisjobs\system\publishingtools_gpserver\.submitted\<ITEM ID>.tmp (There is not enough space on the disk)
用于托管 ArcGIS QuickCapture 的计算机的磁盘空间不足。 由此导致 ArcGIS Server Windows 服务账户丢失为 ArcGIS Server 中的文件夹设置的权限。
Note: The following workaround may require the assistance of the organization's IT team.
C:\arcgisserver
C:\Program Files\ArcGIS\Server
C:\Python27 (version 10.9.1 and older)
文章 ID: 000032083
获取来自 ArcGIS 专家的帮助
立即开始聊天
