操作方法
ArcGIS Pro 允许通过 Portal for ArcGIS 从 ArcGIS Enterprise 添加服务。 在某些情况下,将服务从 ArcGIS Enterprise 添加到 ArcGIS Pro 会失败,并返回以下错误消息:
Error: code:500, FATAL: remaining connection slots are reserved for non-replication superuser connections, Internal server error.
在 ArcGIS Pro 中,此错误消息可能会与另一个错误消息一起显示,即“错误:无法添加数据:<服务 URL>”。
已达到允许与关系数据存储建立的最大连接数。 连接限制还包括 ArcGIS Data Store 内部进程,最多需要 5 个连接。
按照以下工作流解决错误消息并将服务从 ArcGIS Enterprise 添加到 ArcGIS Pro。
Note: On the ArcGIS Data Store machine, run the describedatastore command utility to check the maximum number of connections allowed to the relational data store. Refer to ArcGIS Enterprise: ArcGIS Data Store command utility reference for more information.
Note: Ensure the machine has enough resources before increasing the maximum number of connections allowed in ArcGIS Data Store. Refer to ArcGIS Enterprise: ArcGIS Data Store 11.4 system requirements and the '--max-connections' configuration option under the changedbproperties section for additional information.
文章 ID: 000028912
获取来自 ArcGIS 专家的帮助
立即开始聊天
