操作方法
操作方法:在 ArcGIS Pro 图例中创建并显示图层符号系统描述
Last Published: July 19, 2023
摘要
Descriptions are additional text that can be displayed in a legend instead of, or in addition to, class labels. This article describes how to create and display layer symbology descriptions in legends in ArcGIS Pro.
Legend descriptions are only applied when items are symbolized as a single symbol rather than in groups or categories.
过程
  1. In ArcGIS Pro, add the feature layer to a project.
  2. Right-click the layer in the Contents pane, and click Symbology.
  3. In the Symbology pane, fill in the Label and Description fields as desired.
The Symbology pane with the Label and Description fields filled.
  1. In the same project, insert a layout, and insert a map frame containing the feature layer to the layout.
  2. Add a legend to the layout.
  3. Right-click the legend, and click Properties.
  4. In the Format Legend pane, under Legend Items, click Show properties.
  5. In the Format Legend Item pane, under Show, check the Descriptions check box.
The Format Legend Item pane with the Description check box checked to show the description.
The image below shows the label and description of a layer symbology are displayed in a legend.
The legend with a label and description.
文章 ID: 000024808
获得人工智能支持
使用 Esri Support AI Chatbot 快速解决您的问题。
立即开始聊天
相关信息
发现关于本主题的更多内容
获取来自 ArcGIS 专家的帮助
联系技术支持部门
立即开始聊天
转至下载选项
