操作方法
操作方法:创建一个测试打印机并将其设置为 Windows 默认打印机
Last Published: February 9, 2024
摘要
Instructions provided describe how to create a high-resolution test printer, and set it as the default.
This procedure is used to test various output problems encountered with ArcGIS Desktop applications. For more information about the interaction of the default printer with ArcMap's export, see the link in the Related Information section.
过程
Windows XP
  1. Navigate to Start > Control Panel > Printers and Faxes.
  2. Double-click Add printer. Click Next.
  3. Check the first available local printer port, for example: LPT1. Clear Automatic if it is selected. Click Next.
  4. Select Agfa as the manufacturer and AGFA-AccuSet v52.3 as the printer. Click Next.
 If your operating system is Windows Vista or newer, you may not see an entry for the printer listed above.  In this case, choose a large format, high resolution printer such as an HP DesignJet.  The key is to choose a printer that has a large form size and a high resolution.
  1. Select Not Shared. Click Next.
  2. Select No for the option to print a test page. Click Finish.
  3. Right-click this printer in the Printer Manager window and select Default.
Windows 7
  1. Click Start, and click Devices and Printers.
  2. Click Add a printer.
  3. In the Add printer dialog, click Add a local printer.
  4. Under Choose a printer port, select Use an existing port, and use the first available port (LPT1). Click Next.
  5. Under Install the printer driver, select a large-format, high-resolution printer. Click Next.
  6. Type a name for the printer and click Next.
  7. Under Printer Sharing, select Do not share this printer. Click Next.
  8. Select Set as default printer, and click Finish.
Windows 10
  1. Right-click the Windows (Start) icon, and click Settings.
  2. In the Windows Settings dialog, click Devices.
  3. In the Bluetooth & other devices dialog, click Printers & scanners.
  4. In the Printers & scanners dialog, uncheck the Let Windows manage my default printer box, then click Add a printer or scanner.
  5. Scroll down the list of printers, and click The printer that I want isn't listed.
  6. In the Add Printer dialog, select Add a local printer or network printer with manual settings, and click Next.
  7. Under Choose a printer port, select Use an existing port: LPT1 (Printer Port), and click Next.
  8. Under Install the printer driver, select a large-format, high-resolution printer. Click Next.
  9. Under Which version of the driver do you want to use?, choose Use the driver that is currently installed (recommended), and click Next.
  10. Type a name for the printer and click Next.
  11. Under Printer Sharing, select Do not share this printer, and click Next.
  12. Select Set as default printer, and click Finish.
文章 ID: 000008077
接收通知并查找新问题或常见问题的解决方案
从我们全新的 AI 聊天机器人中获得简明答案和视频解决方案。
下载 Esri 支持应用程序
相关信息
发现关于本主题的更多内容
获取来自 ArcGIS 专家的帮助
联系技术支持部门
下载 Esri 支持应用程序
转至下载选项
