操作方法
操作方法:在 ArcMap 中计算线或面要素的折点数量
Last Published: January 31, 2024
摘要
Instructions provided describe how to populate a new field with the number of vertices for each feature in a polygon or line feature class.
The procedure below is for ArcGIS 10 and later versions. Please see the article in the Related Information section below for instructions for ArcGIS versions 9.3.1 and earlier.
过程
  1. Right-click the layer to be evaluated in the Table of Contents and click Open Attribute Table.
  2. From the Table Options drop-down, click Add Field to add a new field to the table.
  3. Name the field VxCount and select Long Integer for the field type. Click OK.
  4. Right-click the heading of the new field and click Field Calculator.
The geoprocessing tool, Calculate Field, can also be used to populate the field.
  1. Under Parser, select Python.
  2. In the main expression box, set:
VxCount = !shape!.pointcount
[O-Image] Field Calculator
  1. Click OK.
文章 ID: 000011230
获得人工智能支持
使用 Esri Support AI Chatbot 快速解决您的问题。
立即开始聊天
相关信息
发现关于本主题的更多内容
获取来自 ArcGIS 专家的帮助
联系技术支持部门
立即开始聊天
转至下载选项
