操作方法
访问 Portal for ArcGIS 网站时,将返回以下错误:
"Could not access any Portal machines. Please contact your system administrator"
升级 Portal for ArcGIS 可能会导致此错误。 升级 Portal for ArcGIS 计算机后,Portal for ArcGIS 配置发生了变化。
Note: In certain instances, the ArcGIS Web Adaptor must be re-installed or reconfigured to reflect the newly configured Portal for ArcGIS. The following document describes this: Configure ArcGIS Web Adaptor. The following document describes the considerations to be taken before upgrading Portal for ArcGIS: Upgrade Portal for ArcGIS.
文章 ID: 000013741
获取来自 ArcGIS 专家的帮助
立即开始聊天
