操作方法
Note: Beginning at version 3.3, ArcGIS Pro has switched entirely to leveraging the Microsoft Edge WebView2 Runtime and will no longer install a Fixed Version during the application setup process, making this workflow valid for ArcGIS Pro version 2.9 through 3.2 only. If the Microsoft Edge WebView2 Runtime is not already installed on your machine, it can be downloaded using the Evergreen Bootstrapper or Evergreen Standalone Installer from Microsoft.
关于 WebView2
自 2.9 版本起,ArcGIS Pro 开始采用 Microsoft Edge WebView2 在应用程序用户界面中呈现 HTML 和 JavaScript 内容。 WebView2 控件使用 Microsoft Edge (Chromium) 作为处理和渲染此类内容的引擎。
WebView2 Runtime 分布
Microsoft Edge WebView2 的运行依赖于计算机上安装的相应运行时环境。 该运行时包含了 WebView2 用以处理 HTML 和 JavaScript 内容的 Chromium 浏览器代码。 WebView2 运行时存在两种发行版本:修正版本和 Evergreen。 默认情况下,ArcGIS Pro 使用修正版本,但可以配置为使用 Evergreen。
Warning: The instructions below include making changes to essential parts of your operating system. It is recommended that you backup your operating system and files, including the registry, before proceeding. Consult a qualified computer systems professional, if necessary. Esri cannot guarantee results from incorrect modifications while following these instructions. Therefore, use caution and proceed at your own risk.
Note: The following procedure modifies the HKEY_LOCAL_MACHINE portion of the Windows registry, and requires Administrator permission to complete.
HKEY_ LOCAL_MACHINE\Software\ESRI\ArcGISPro\Settings
要切换回修正版本运行时,可在注册表编辑器中将 WebViewEvergreenMode 的值从 1 改为 0,或直接删除 WebViewEvergreenMode 值项。
文章 ID: 000026540
获取来自 ArcGIS 专家的帮助
立即开始聊天
