操作方法
GIS 经理、DBA 和管理员有时需要自动化工作流,例如启用地理数据库。 提供的说明将介绍如何使用 Python 脚本来执行此操作。
以下 Python 脚本演示了如何创建连接文件并启用地理数据库。
注: 要运行启用企业级地理数据库地理处理工具,您必须在计算机(通过其连接到数据库并启用地理数据库功能)上安装 ArcGIS Desktop(Desktop Standard 或 Desktop Advanced)、ArcGIS Engine Geodatabase Update 或 ArcGIS Server。
根据环境修改以下参数:
temp = r"C:/temp" auth_file = "C:/Authorizationfile/aut101/Server_Ent_Adv.ecp" Connection_File_Name = "Nidhi_oracle2.sde" database_platform = "ORACLE" instance = "lclinton2/testoracle" database = "" account_authentication = "DATABASE_AUTH" username = "sde" password = "sde" save_user_pass="TRUE" dba_username = "sys" dba_password = "manager"
Python 脚本:
import arcpy, os, sys, string def CreateGeoDB(temp,auth_file, Connection_File_Name,database_platform,instance,database,account_authentication,username,password,save_user_pass,dba_username,dba_password): #Create connection file arcpy.CreateDatabaseConnection_management(temp,Connection_File_Name,database_platform,instance,account_authentication,username,password,"SAVE_USERNAME","","","TRANSACTIONAL","","") print "Created sdeconnection" arcpy.EnableEnterpriseGeodatabase_management(temp + os.sep + Connection_File_Name, auth_file) print "Enabled database" if __name__ == "__main__": temp = r"C:/temp" auth_file = "C:/Authorizationfile/aut101/Server_Ent_Adv.ecp" Connection_File_Name = "Nidhi_oracle2.sde" database_platform = "ORACLE" instance = "lclinton2/testoracle" database = "" account_authentication = "DATABASE_AUTH" username = "sde" password = "sde" save_user_pass="TRUE" dba_username = "sys" dba_password = "manager" CreateGeoDB(temp,auth_file, Connection_File_Name,database_platform,instance,database,account_authentication,username,password,save_user_pass,dba_username,dba_password)
文章 ID: 000011776
获取来自 ArcGIS 专家的帮助
立即开始聊天
