常见问题
常见问题解答:AutoCAD DWG 和 DXF 文件在 10.4 版的 ArcMap 中的显示是否不同?
Last Published: September 13, 2023
答案
To avoid drawing all these individual BLOCK layers in ArcMap, just add the Annotation, Point, Polyline, Polygon and Multipatch layers to the map as was done previously.  To add these specific feature types in the Add Data Dialog or in ArcCatalog, double-click the CAD file name and add only the feature types needed to the ArcMap document.
Individual BLOCK layers can also be added to ArcMap along with specific feature types.  This provides access to the values in the attribute TAGs for each type of BLOCK.
Esri recommends not adding the Group Layer from a CAD file to ArcMap, because the Group Layer masks too much information about the data, and also adds all the BLOCK layers to the map, causing a performance lag.  This is documented in BUG-000094769: "DWGs added to ArcMap 10.4 take several minutes to load and may eventually cause the application to stop responding."
文章 ID: 000014382
获得人工智能支持
使用 Esri Support AI Chatbot 快速解决您的问题。
立即开始聊天
发现关于本主题的更多内容
获取来自 ArcGIS 专家的帮助
联系技术支持部门
立即开始聊天
转至下载选项
