Perguntas mais frequentes
Qual é a localização padrão dos logs de auditoria e lmgrd9 (depuração) no Windows ArcGIS License Manager 2021.0 e mais recente?
Last Published: August 4, 2025
Starting with the ArcGIS License Manager 2021.0, the default location of the Audit and lmgrd9 (debug) logs is changing on Windows platforms.
The default location of Audit and lmgrd9 (debug) log files is now:  C:\ProgramData\ArcGIS\LicenseManager
If using the in-place upgrade of ArcGIS License Manager to 2021.0 from a previous version, fresh log files are written to the new location and the previous log files are retained in the former location. If you use third-party software or scripts that read or parse the scripts in the former location, you must update the software or scripts to reflect the new location of the log files.
This does not affect Linux platforms. The location remains the same with Linux ArcGIS License Manager 2021.0.
ID do Artigo: 000025465
Obtenha suporte com IA
Comece a conversar agora
Descubra mais sobre este tema
Ir para as opções de download
