PROBLEMA
Os aplicativos Flash e Silverlight não podem mais acessar o conteúdo e serviços do ArcGIS Online
Last Published: May 6, 2024
Descrição
Esri is removing security policy files from ArcGIS Online that are used by the ArcGIS API for Flex on January 26, 2021, and for the ArcGIS API for Silverlight on October 12, 2021.
This means that after these dates, Flex and Silverlight apps can no longer access any content and/or services from ArcGIS Online. Furthermore, due to security vulnerabilities associated with running Flash, Adobe no longer supports Flash as of December 31, 2020, and is taking steps to block Flash-based apps from running altogether.
Causa
The ArcGIS API for Flex and the ArcGIS API for Silverlight were retired in June 2016. However, Esri kept these policy files accessible so developers who wanted to continue to use their deployed Flex and Silverlight apps could access content and services on ArcGIS Online:
These resources are being removed to protect customers from security vulnerabilities; in line with Adobe, Microsoft, and major browser vendors:
Solução ou Solução Provisória
If you have a Flex- or Silverlight-based app in production, Esri highly encourages migration to a JavaScript-based app using the ArcGIS API for JavaScript. The ArcGIS API for JavaScript is the focus of Esri’s web-based development and innovation, and far exceeds the capabilities of the older Flex and Silverlight APIs on many fronts.
ID do Artigo: 000024962
Obtenha suporte com IA
Comece a conversar agora
Informações Relacionadas
Descubra mais sobre este tema
Ir para as opções de download
