PROBLEMA
Não é possível exibir pop-ups de feições no ArcGIS Pro
Last Published: August 3, 2023
Descrição
In ArcGIS Pro, when clicking features on a map to identify them, the pop-ups are not displayed even though the 'Enable Pop-ups' option is selected for the feature layer.
Causa
Feature pop-ups in ArcGIS Pro are displayed based on the Explore tool layer order options. Refer to ArcGIS Pro: Open a pop-up for information on the functionality of each option. For example, feature pop-ups are not displayed for other layers when the 'Make this the only selectable layer' option is enabled for one layer.
Solução ou Solução Provisória
To resolve the issue, select the Visible Layers option in the Explore tool. Complete the steps below to do so:
  1. On the top ribbon, click the Map tab.
  2. On the Map tab, click the Explore drop-down arrow, and select Visible Layers.
The screenshot image shows the Explore tool options in ArcGIS Pro.
  1. On the map, zoom in and pan to the intended view area of the features. Click a feature, and the pop-up displays.
The screenshot image shows the pop-up is displayed for the selected feature.
ID do Artigo: 000024510
Obtenha suporte com IA
Comece a conversar agora
Informações Relacionadas
Descubra mais sobre este tema
Ir para as opções de download
