PROBLEMA
In ArcGIS Pro, changes made in a map are reflected on the legend in a layout. However, in some instances, the legend does not honor the layer visibility of the map. In this example, the Polygon layer is unchecked in the Contents pane but is displayed in the legend in the layout.
The layer visibility is not synchronized.
To resolve the issue, follow the workflow below to synchronize the layer visibility of the legend.
The layer visibility is synchronized. The unchecked layer in the Contents pane is not displayed in the legend.
ID do Artigo: 000026152
Comece a conversar agora
