PROBLEMA
ArcGIS Pro falha ao iniciar com um erro de aplicativo sério
Descrição
When starting ArcGIS Pro, the application fails and returns the following error:
Error:
ArcGIS Pro has encountered a serious application error and is unable to continue.
User-added image
Causa
This is a generic error message that can be returned due to various causes, however when starting ArcGIS Pro, this error often occurs because the user.config file is corrupted.
Solução ou Solução Provisória
Create a new .config file
To locate and delete the corrupted user.config file by following the steps below:
It may be necessary to enable viewing of hidden folders to view the AppData folder in Windows. For more information, refer to Microsoft: Show hidden files.
  1. Navigate to the following folder path:
C:\Users\<USERNAME>\AppData\Local\ESRI\ArcGISPro.exe_Url_usrdyax2a4fbxzcclmgcafuxifk3o351\1.4.0.0\
  1. Delete the user.config file.
  2. Start ArcGIS Pro.
Rename the ESRI folder
By renaming the ESRI folder to a name other than ESRI, a new ESRI folder is created with a new .config file when starting ArcGIS Pro.
  1. Navigate to the following path:
C:\Users\USERNAME\AppData\Local\
  1. Rename the ESRI folder (for example, to 'ESRI-old'.)
ID do Artigo: 000015754
Obtenha suporte com IA
Comece a conversar agora
Informações Relacionadas
Descubra mais sobre este tema
Ir para as opções de download
