Instrução
Note: This article applies to retired ArcMap versions 8.x. Later versions of ArcGIS may contain different functionality, as well as different names and locations for menus, commands and geoprocessing tools.
Algumas configurações que controlam as operações do ArcMap não são acessíveis por meio da interface. A ferramenta Configurações Avançadas do ArcMap fornece uma maneira de ajustar algumas dessas configurações.
Note: For more information about what the Advanced Settings Utility does, refer to the MS Word document called "ArcMap Advanced Settings Registry Keys. doc" that accompanies the utility. It is found in the same directory as the utility.
ID do Artigo: 000003442
Comece a conversar agora
