Instrução
Selecionar vários valores usando a ferramenta Selecionar Por Atributos
Last Published: April 19, 2024
Resumo
When using the Select by Attributes tool, query operators such as IN, LIKE, OR, and NOT can be used to determine the type of selection for multiple values. Refer to ArcMap: SQL reference for query expressions used in ArcGIS for more information on the query operators types.
Procedimento
The following workflow uses the IN query operator to select multiple values. This workflow is also applicable to the other query operators; LIKE, OR, and NOT.
  1. In ArcMap, open the attribute table of the layer.
  2. Click the Table Options button The Table Options button > Select By Attributes.
  3. Double-click the field containing the desired values.
  4. Add a space after the field name and type IN.
  5. Select the parentheses icon.
The Select by Attributes window displays the highlighted parenthese.
  1. In the parentheses, select or type the values. Separate each value with a comma.
If it is a text field, apply single quotes around each value.
The Select by Attributes window displaying the <field name> IN (<field value>, <field value>) expression.
The following is a sample query:
  1. Click Apply.
This method can also be used to select numeric and string values.
ID do Artigo: 000009011
Obtenha suporte com IA
Comece a conversar agora
Informações Relacionadas
Descubra mais sobre este tema
Ir para as opções de download
